disable bgp export vr
                disable bgp export {vr} vr_name route_type {address-family} vpnv4
        Description
            For IPv4 and IPv6 routes, this command disables the PE router to
                export and redistribute local VRF routes to remote PE routers through
                    BGP.
        Syntax Description
                            | vr | Specifies the source VPN VRF
                                of the exported routes. |
                            | vr_name | Specifies the name of the
                                source VPN VRF. |
                            | route_type | Specifies the source or origin
                                of the route types to be exported to remote PE routers. Valid Types:
                                blackhole, direct, and bgp. |
                            | address-family | Specifies the address family
                                for the exported routes. Valid types are ipv4-unicast,
                                vpnv4. |
                            | vpn4 | Specifies that routes from the VRF are
                                exported as vpnv4 routes over MPBGP. |
        Usage
                Guidelines
             This command disables a PE router to advertise learned routes
            from CE routers to remote PE routers in a Service Provider's backbone. Executing this
            command allows the PE router to convert VRF native IPv4 routes into VPN-IPv4 route,s and
            advertise to all remote PE BGP neighbors as VPN-IPv4 routes.
                - For Layer 3 VPNs, you must enter the disable bgp
                        export vr command in the context of the VRF that supports the Layer
                    3 VPN.
- When the export source is the Layer 3 VPN, you can specify direct, or remote-vpn
                    to disable route export to the VRF. The destination address family must be
                    ipv4‑unicast.
- This export command is applicable in Parent VR context only. If you execute it
                    in a VRF context, an error message is returned.
- The source VPN VRF must be a child of the Parent VR.
- BGP need not be added to a VPN VRF to export routes from a VPN VRF.
- The direction of where the redistribution is targeted is implicit on the
                    keywords used, For eg:- remote-vpn only applies to remote routes from PE
                    redistributed to CE, hence we cannot use it with address family vpnv4. Similarly
                    bgp only applies to EBGP routes from CE exported as VPN routes, hence we use it
                    only with address family vpnv4. Other sources such as “static” and “direct” are
                    redistributed both ways.
            The following command disables BGP to advertise a vpnv4 route
                named "corp1_vpn_vrf":
            disable bgp export "corp1_vpn_vrf" bgp address-family vpnv4
            This command was
first available in ExtremeXOS 10.1.
            This command required
a specific license in ExtremeXOS 11.1.
            The blackhole option
was added in ExtremeXOS 12.1.3.
            Support for IPv6 was added
in ExtremeXOS 12.6 BGP.
            Support for Layer 3 VPNs was added in ExtremeXOS 15.3.
        Platform Availability
            This command is available on platforms that support the
                appropriate license. For complete information about software licensing, including
                how to obtain and upgrade your license and which licenses support the BGP feature,
                see the
    Switch Engine v33.1.1 Licensing Guide
    document.
